Restoring the Original Chartplotter Factory Settings
NOTE: This affects all devices on the network.
  1. Select Settings menu > System > System Information > Reset.
  2. Select an option:
    • To reset the device settings to the factory default values, select Reset Default Settings. This restores the default configuration settings, but does not remove saved user data, maps, or software updates.
    • To reset all settings in all devices in the station to the factory default values, select Reset Station Settings. This restores the default configuration settings, but does not remove saved user data, maps, or software updates
    • To clear saved data, such as waypoints and routes, select Delete User Data. This does not affect maps or software updates.
    • To clear saved data and reset device settings to the factory default values, disconnect the chartplotter from the Garmin® Marine Network, and select Delete Data and Reset Settings. This does not affect maps or software updates.
GUID-3E67C80C-0812-4EEC-BC60-699751B9CF6F v15
June 2026
