Trolling Motor Settings
On the remote control, select .
- Wi-Fi
Sets the wireless network preferences for the trolling motor (Wireless Network Settings).
- Calibrate
Calibrates the trolling motor compass (Calibrating the Trolling Motor) and sets the trolling motor bow offset (Setting the Bow Offset).
- Units
Sets the units of measure.
- Battery
Changes the appearance of the trolling motor battery indicator from an icon to a numeric value.
- Prop Stow Side
Sets which side of the trolling motor the propeller rotates to when stowing the trolling motor. This is helpful when you store other items near the stowed propeller.
- Auto Power On
Turns on the trolling motor when you apply power to the system.
- Heading Hold
Sets the behavior of the heading hold feature (Changing the Heading Hold Behavior).
- Nav. Arrival
Sets the behavior of the trolling motor when you reach the end of a route. With the Anchor Lock setting, the trolling motor holds the position using the anchor lock feature when the boat reaches the end of the route. With the Manual setting, the propeller turns off when the boat reaches the end of the route.
When using Manual for the Nav. Arrival setting, you must be ready to take control of the boat.
- Anchor Gain
Sets the response of the trolling motor when in anchor lock mode. If you need the trolling motor to be more responsive and move quicker, increase the value. If the motor is moving too much, decrease the value.
- Navigation Gain
Sets the response of the trolling motor when navigating. If you need the trolling motor to be more responsive and move quicker, increase the value. If the motor is moving too much, decrease the value.
- Clear User Data
Deletes all saved waypoints, routes, tracks, and you active track.NOTE: If you are connected to a chartplotter, selecting this clears user data from both the trolling motor and the connected chartplotter.
- Restore Defaults
Resets the trolling motor settings to the factory default values.
