Steering the Trolling Motor Manually
Manual mode is the default operational mode of the trolling motor. In manual mode, you can adjust the direction and speed of the trolling motor as needed.
NOTE: The trolling motor is in manual mode by default when you turn it on.
  1. If necessary, on the remote control, select Manual control button.
  2. Select an action:
    • Using the remote control, press Left directional arrow button and Right directional arrow button to steer.
      NOTE: You can also use gesture controls to steer the boat manually using the remote control (Using Gesture Controls to Steer).
    • Using the foot pedal, push the pedal with your toes and heel to steer.
GUID-16D2E284-7D08-461D-80CE-7D490C67A3EB v7
April 2025
