Maintaining Your Heading
Before you can use the Heading Hold feature, you must calibrate the trolling motor (Calibrating the Trolling Motor).
You can activate Heading Hold to keep your boat moving in the same compass direction. The motor may adjust your heading automatically to compensate for drift caused by factors such as wind and currents.
  1. Steer the boat in the direction you want to go.
  2. On the remote control or foot pedal, select Heading hold button.
    NOTE: You can adjust the direction by pressing Left directional arrow button and Right directional arrow button, or by using gesture controls (Using Gesture Controls to Adjust the Heading Hold).
To disable Heading Hold and return to manual mode, you must select Heading hold button, Manual control button, or step on the foot pedal.
GUID-16D2E284-7D08-461D-80CE-7D490C67A3EB v7
April 2025
