Changing the Heading Hold Behavior
By default, the Heading Hold feature may adjust your heading to compensate for drift and keep your boat moving in the same direction. If preferred, you can configure the Heading Hold feature to ignore drift and simply keep the bow of your boat pointing in the same direction.
- On the remote control, select .
- Select Vessel Align.
You can select Go To to revert back to the default Heading Hold mode.
Parent Topic: Maintaining Your Heading
