Pairing the Foot Pedal
The foot pedal is paired with the trolling motor at the factory, but you may need to pair them again if the connection is broken.
  1. Turn on the trolling motor.
  2. On the trolling motor display panel, press Power button three times to enter pairing mode.
    Synchronization icon on the trolling motor display panel illuminates blue as it searches for a connection.
  3. Bring the foot pedal within 1 m (3 ft.) of the display panel on the trolling motor.
  4. Connect the foot pedal to power using the power cable, or insert batteries to turn it on.
  5. Within 30 seconds of turning on the foot pedal, hold Anchor lock button until the status LED on the foot pedal illuminates blue.
  6. Release Anchor lock button.
    The status LED on the foot pedal illuminates blue as it searches for a connection, then turns off when it pairs successfully with the trolling motor.
    Synchronization icon on the trolling motor display panel changes to green when the connection is successful.
GUID-16D2E284-7D08-461D-80CE-7D490C67A3EB v7
April 2025
