Foot Pedal
Dimensions (L×W×H) |
303 × 221 × 110 mm (1115/16 × 811/16 × 4 5/16 in. |
Weight |
1.8 kg (4 lb) |
Operating temperature |
From -15° to 55°C (5° to 131°F) |
Storage temperature |
From -40° to 85°C (-40° to 185°F) |
Water rating |
IEC 60529 IPX7 |
Material |
Plastic |
Input voltage |
From 10 to 45 Vdc |
Rated input voltage |
12/24/36 Vdc |
Typical input current |
< 1 mA @ 12 Vdc |
Max input current |
10 mA @ 12 Vdc |
Fuse (on the power cable) |
2 A mini-blade type |
Power cable length |
2 m (6.6 ft.) |
Battery type |
Two AA batteries (Alkaline, NiMH, or lithium. Not included.) |
Battery life |
At least 1 year |
Radio frequency |
2.4 GHz @ 0.72 dBm nominal |
Compass-safe distance |
60 cm (2 ft.) |
