Calibrating the Remote Control
NOTICE
Calibrate the electronic compass outdoors. To improve heading accuracy, do not stand near objects that influence magnetic fields, such as vehicles, buildings, and overhead power lines.
You must calibrate the compass in the remote control before you can control the motor using gestures. If the gesture controls are not working properly after calibration, you can repeat this process as often as needed.
  1. Select Menu button > Settings > Remote Control > Calibrate.
  2. Select Start, and follow the on-screen instructions.
GUID-16D2E284-7D08-461D-80CE-7D490C67A3EB v7
April 2025
