Maintenance Needs and Schedule
After using the motor in salt water or brackish water, you must rinse off the entire motor with fresh water, and apply a water-based silicone spray using a soft cloth. You should avoid spraying jets of water at the cap on the top of the shaft when rinsing the motor.
To maintain your warranty, you must perform a series of routine maintenance tasks as you prepare your motor for the season. If you use or transport the motor in dry, dusty environments (traveling on gravel roads, for example) you should perform these tasks more often during the season.
For detailed procedures and information on service and replacement parts, download the Force® Trolling Motor Maintenance Manual from garmin.com/manuals/force_trolling_motor .
Examine the power cable for wear, and patch, repair, or replace as necessary
Check and clean the power terminals and tighten the nuts, if necessary
Lubricate the hinges and bushings
Clean and lubricate the stow and deploy latch mechanism
Check the mount rails, and replace them if necessary
Check the mount bumper, and replace it if necessary
Clean or replace the anodes in the propeller drive motor
