Calibrating the Trolling Motor
You must calibrate the compass in the trolling motor before you can use the autopilot features. For the best results, you should calibrate the motor on a day with little or no wind on calm water. You can repeat the calibration process if the autopilot features are not performing as expected.
  1. Drive the boat to an open area of calm water and stop moving.
    The boat must be stationary to begin the calibration process.
  2. Make sure the trolling motor is deployed (Deploying the Motor from the Stowed Position).
  3. On the remote control, select Menu button > Settings > Trolling Motor > Calibrate > Compass.
  4. Using a foot pedal, remote control, or outboard motor to steer, follow the on-screen instructions to calibrate the compass.
GUID-16D2E284-7D08-461D-80CE-7D490C67A3EB v7
April 2025
