Trolling Motor
Weight (motor, mount, and cables) |
50 in. model: 30 kg (66 lb.) 57 in. model: 31.75 kg (70 lb.) |
Weight (stabilizer) |
0.54 kg (1.2 lb.) |
Operating temperature |
From -5° to 40°C (from 32° to 104°F) |
Storage temperature |
From -40° to 85°C (-40° to 185°F) |
Material |
Mount and motor housing: aluminum Shaft cap, display panel, and side panels: plastic Motor shaft: fiberglass |
Water rating |
Shaft cap: IEC 60529 IPX51 Steering motor housing: IEC 60529 IPX72 Display panel housing: IEC 60529 IPX7 Propeller drive motor housing: IEC 60529 IPX83 |
Compass safe distance |
91 cm (3 ft.) |
Power cable length |
50 in. model: 1.2 m (4 ft.) 57 in. model: 1.1 m (3.5 ft.) |
Input voltage |
From 20 to 45 Vdc |
Input amperage |
60 A continuous |
Breaker (not included) |
42 VDC or greater, suitable for 60 A continuous NOTE:
You can protect the system by using a larger circuit breaker, not to exceed 90 A, if you are operating under high temperatures or if you are sharing the circuit with other devices. You should verify that your boat wiring meets marine wiring standards using a larger breaker before changing it.
Main power usage at 36 Vdc 60 A |
Off: 72 mW Full power: 2160 W |
Radio frequency |
Bluetooth®: 2.4 GHz @ 28 dBm nominal Wi‑Fi®: 802.11 b/g/n @ 20 mhz |
