Pairing the Remote Control
The remote control is paired with the trolling motor at the factory, but you may need to pair them again if the connection is broken.
  1. Turn on the trolling motor.
  2. On the trolling motor display panel, press Power button three times to enter pairing mode.
    Synchronization icon on the trolling motor display panel illuminates blue as it searches for a connection.
  3. Bring the remote control within 1 m (3 ft.) of the display panel on the trolling motor.
  4. Turn on the remote control.
  5. On the remote control, select Menu button > Settings > Remote Control > Pair > Start.
    Synchronization icon on the trolling motor display panel illuminates green when the connection is successful.
Pairing an Additional Remote Control
After you have connected the first remote control, you can use it to pair a second remote control.
In addition to a foot pedal, a wearable, and a chartplotter, you can have up to two remote controls connected to your trolling motor at the same time.
  2. On an already paired remote control, select Menu button > Settings > Remote Control > Add Additional Remote.
    The trolling motor display panel illuminates blue when the it is ready to pair.
  3. Bring the additional remote control within 1 m (3 ft.) of the display panel on the trolling motor.
  4. Turn on the additional remote control.
  5. On the additional remote control, select Menu button > Settings > Remote Control > Pair > Start.
    Synchronization icon on the trolling motor display panel illuminates green when the connection is successful. Device Found is shown on the original remote control, and Connected is shown on the additional remote control.
GUID-16D2E284-7D08-461D-80CE-7D490C67A3EB v7
April 2025
