Holding Your Position
Before you can use the anchor lock feature, you must calibrate the trolling motor (Calibrating the Trolling Motor).
The anchor lock feature is an autopilot function that uses GPS to set and maintain your position using the trolling motor, acting as if you deployed a physical anchor.
  1. If necessary, drive the boat to a location you want to set the anchor lock.
  2. On the remote control or foot pedal, select Anchor lock button.
    NOTE: You can adjust the anchor lock position 1.5 m (5 ft.) by pressing an arrow key on the remote control, or by using gesture controls (Using Gesture Controls to Adjust Your Held Position ).
To disable anchor lock, you can press Anchor lock button again, or steer with the foot pedal.
GUID-16D2E284-7D08-461D-80CE-7D490C67A3EB v7
April 2025
