Setting the Bow Offset
Based on the installation angle, the trolling motor may not align with the center line of your boat. For the best results, you should set the bow offset.
  1. Using the remote control, adjust the angle of the trolling motor Callout number 1 so it aligns with the center line of your boat Callout number 2, pointing straight forward.
    Setting the bow offset example
  2. On the remote control, select Menu button > Settings > Trolling Motor > Calibrate > Bow Offset.
  3. Press Left directional arrow button or Right directional arrow button to adjust the bow offset.
  4. Press Down directional arrow button to set the bow offset.
  5. Repeat this procedure if necessary.
GUID-16D2E284-7D08-461D-80CE-7D490C67A3EB v7
April 2025
