Disabling the Autopilot Buttons on the Foot Pedal
Before you can disable or re-enable the autopilot buttons on the foot pedal, you must make sure the foot pedal has power.
You can individually disable the heading hold button (Heading hold button) and the anchor lock button (Anchor lock button) on the foot pedal to avoid accidentally engaging them.
Quickly press the button six times to disable it.
The status LED turns red for 1 second to indicate that the button is disabled.
TIP: To enable the button again, quickly press it six times. The status LED turns green for one second to indicate that the button is enabled.
GUID-16D2E284-7D08-461D-80CE-7D490C67A3EB v7
April 2025
