Deploying the Motor from the Stowed Position
CAUTION
When stowing or deploying the motor, maintain stable footing and be aware of slick surfaces around the motor. Losing your footing while stowing or deploying the motor may result in injury.
CAUTION
When stowing or deploying the motor, be aware of the risk of entrapment or pinching from moving parts, which can result in personal injury.
  1. Disengage the safety strap.
  2. Pull the pull-cable back until it stops to release the latch, and continue to hold it tight.
  3. Lift the motor up and forward using the pull-cable, then lower it slowly into the deployed position.
  4. If necessary, push down on the mount arm to lock the motor in the deployed position.
GUID-16D2E284-7D08-461D-80CE-7D490C67A3EB v7
April 2025
