Navigating to the Start of the Active Track
The track currently being recorded is called the active track. You can navigate from your current position back to the starting point of the active track along the path you traveled.
  1. Select Menu button > Tracks > Backtrack.
  2. Turn on the propeller (Turning the Propeller On and Off).
    The trolling motor navigates back to the starting point of the active track along the path you traveled (Navigating).
GUID-16D2E284-7D08-461D-80CE-7D490C67A3EB v7
April 2025
