Securing the Safety Strap
NOTICE
You are required to secure the safety strap when stowing the trolling motor. Failure to secure the trolling motor in the stowed position using the safety strap may result in unexpected deployment, damaging the boat and trolling motor.
The safety strap holds the motor securely to the base in the stowed position and prevents unintended deployment.
  1. With the motor in the stowed position, lift the long end of the strap Callout number 1 over the top of the motor.
    Device in stowed postition with callouts
  2. Feed the end of the strap through the buckle Callout number 2 on the other end of the strap.
  3. Pull the strap through the buckle until it holds the motor securely to the mount.
  4. Pull the strap away from the buckle, and push down to fasten it to the other side of the strap.
GUID-16D2E284-7D08-461D-80CE-7D490C67A3EB v6
January 2025
