Moving a Saved Waypoint
  1. Select Where To > Points.
  2. Select a waypoint.
  3. Select Position.
  4. Indicate a new location for the waypoint:
    • To move the waypoint using coordinates, select Enter Coordinates, enter the new coordinates, and select Done or Cancel.
    • To move the waypoint while using the chart, select Use Chart, select a new location on the chart, and select Move Waypoint.
    • To move the waypoint using the vessel's current position, select Use Current Position.
    • To move the waypoint using a range (distance) and bearing, select Enter Range/Bearing, enter the information, and select Done.
June 2026
