Adjusting the Tack and Gybe Speed
You can adjust the turn rate speed when performing tack and gybe maneuvers. You can adjust the speed for each maneuver separately.
  1. From the autopilot screen, select Menu options symbol > Autopilot Setup > Sailing Setup.
  2. Select Tack Speed or Gybe Speed, and adjust the speed.
    The higher you set the speed, the faster the turn rate during the maneuver.
    NOTE: The turn rate is also affected by the vessel speed.
September 2026
