Enabling the Shadow Drive Feature
WARNING
If the Shadow Drive™ feature is disabled, steering the boat manually will not disengage the autopilot system. You must use the helm control or connected chartplotter to disengage the autopilot system.
NOTE: The Shadow Drive feature is not available on all autopilot models.
If the Shadow Drive feature has been disabled, you must enable it again before you can steer the boat manually to disengage the autopilot system.
  1. From the autopilot screen, select Menu options symbol > Autopilot Setup > Shadow Drive Setup.
  2. If Disabled is shown, select Shadow Drive to enable the Shadow Drive feature.
The Shadow Drive feature is enabled. You can repeat these steps to disable the feature again.
June 2026
