Setting the Fuel Alarm
CAUTION
The Beeper setting must be turned on to make alarms audible (Sounds and Display Settings). Failure to set audible alarms could lead to injury or property damage.
Before you can set a fuel level alarm, you must connect a compatible fuel flow sensor to the chartplotter.
You can set an alarm to sound when the total amount of remaining onboard fuel reaches the level you specify.
  1. Select Settings menu > Alarms > Fuel > Total Fuel Onboard > On.
  2. Enter the remaining amount of fuel that triggers the alarm, and select Done.
June 2026
