LED Light Scenes
A scene is a collection of LED lights that you can set to change to a defined set of colors and effects. You can create up to 20 scenes, with any number of connected lights or light groups in each scene. You can configure all of the lights in a scene to behave the same way or independently of one another.
A scene is different from a light group because you can add a light or light group to any number of scenes you create. You are not limited to how many scenes contain a connected light or light group. A light group is more restrictive and defines specific lights that you want to regularly behave the same way (LED Light Groups).
NOTE: LED light scenes you create are synchronized between chartplotters connected using a wired or wireless NETWORK connection only. LED light scene information is not synchronized across the NMEA 2000® network. If you have multiple chartplotters connected through the NMEA 2000 network only, you must create and make changes to LED light scenes on all chartplotters individually. To create and change scenes on compatible Fusion® stereos, you must use the ActiveCaptain® app. See the stereo Owner's Manual for more information.
Creating a new LED Light Scene
  1. From the lighting control screen, select Scenes.
  2. Select Menu options symbol > Create New Scene.
    TIP: You can select Create new scene icon from the lighting control screen at any time to quickly create a new scene.
  3. Enter a name for the scene, and select Done.
    The new scene appears on the lighting control screen.
After creating the scene, you should edit the scene to add or remove lights and define how you want them to behave when you run the scene.
Editing an LED Light Scene
  2. Select Menu options symbol > Edit Scene.
  3. Select the name of the scene.
    TIP: You can select Edit scene icon on a scene directly from the lighting control screen to quickly edit the scene.
  4. To edit the scene behavior, select one or more options:
    • To rename the scene, select Rename, and enter the new name.
    • If you've changed the status and behavior of lights in the scene and want to update the scene to use the present state of all lights in the scene, select Resave Scene.
    • To add or remove lights or light groups from the scene, select Add/Remove Lights, and select the lights and light groups you want to include in the scene.
Starting an LED Light Scene
Before you can start a scene, you must create at least one scene.
  2. Select Play symbol on a scene to start it.
    TIP: If you want to turn off all lights in a scene, select Menu options symbol > Edit Scene, select the name of the scene, and select Turn Off Lights.
Deleting an LED Light Scene
You can remove any LED light scenes you created. Deleting a scene does not affect any lights or light groups that were added to the scene.
  2. Select Menu options symbol > Delete Scene.
  3. Select the name of the scene you want to delete, and select Yes to confirm.
June 2026
