Incoming Distress Calls
If your chartplotter is connected to a compatible VHF radio, your chartplotter alerts you when your VHF radio receives a DSC distress call. If position information was sent with the distress call, that information is also available and recorded with the call.
DSC distress call symbol designates a distress call in the DSC list and marks the position of the vessel on the Navigation chart at the time of the DSC distress call.
Navigating to a Vessel in Distress
The DSC distress call symbol icon designates a distress call in the DSC list and marks the position of a vessel on the Navigation chart at the time of the DSC distress call.
  1. From a chart or 3D chart view, select Menu button > Layers > Other Vessels > DSC > DSC List.
    TIP: You can quickly access the DSC list from the messages and warnings menu (Messages and Warnings ).
  2. Select a position-report call.
  3. Select Review > Navigate To.
  4. Select Go To or Route To.
Man-Overboard Distress Calls Initiated from a VHF Radio
When the chartplotter is connected to a compatible VHF radio with NMEA 2000®, and you initiate a man-overboard DSC distress call from the radio, the chartplotter shows the man-overboard screen and prompts you to navigate to the man-overboard point. If you have a compatible autopilot system connected to the network, the chartplotter prompts you to start a Williamson’s turn to the man-overboard point.
If you cancel the man-overboard distress call on the radio, the chartplotter screen prompting you to activate navigation to the man-overboard location disappears.
September 2026
