Mercury Active Trim Control
WARNING
You are responsible for the safe and prudent operation of your vessel. Mercury® Active Trim Control does not control boat speed, does not steer the boat for you, and does not avoid navigational hazards. Failure to safely operate your boat could result in an accident causing property damage, serious personal injury, or death.
When your chartplotter is connected to a compatible Mercury Active Trim system, you can control the system using the Active Trim overlay on the chartplotter.
Adding the Mercury Active Trim Overlay
  1. From the page where you want to add the overlay, select Menu options symbol > Edit Overlays.
    TIP: You can also select Toolbar icon from the menu bar to quickly change the overlays.
  2. Select Top Bar, Bottom Bar, Left Bar, or Right Bar.
  3. Select Active Trim.
Mercury active trim bar with callouts
1
When enabled, you can manually adjust the trim.
2
When enabled, you can change between Mercury active trim preset profiles.
3
Active trim system status.
Enable or Disable
Select to turn the active trim system on or off.
September 2026
