Station Settings
Select Settings menu > System > Station Information.
Change Station
Sets the entire station to a new set of defaults based on the location of this station. You can also select to use this display as a stand-alone, individual display, instead of grouping it with other displays to make a station.
Display Order
Sets the order of the displays, which is important when using a GRID™ remote input device.
Autopilot Enabled
Allows you to control the autopilot from this device.
Reset Layouts
Resets the layouts in this station to the factory default settings.
Reset Station Settings
Resets all station settings to on all connected devices in the station to the factory default settings, and requires initial station setup.
June 2026
