Skyhook Digital Anchor Control
WARNING
You are responsible for the safe and prudent operation of your vessel. The Skyhook® digital anchor features do not avoid navigational hazards. Failure to safely operate your boat could result in an accident causing property damage, serious personal injury, or death.
When connected to a compatible Mercury® engine, you can use the Skyhook digital anchor overlay on the chartplotter to set and adjust the Skyhook, Drifthook, and Bowhook functions.
When active, the boat attempts to maintain heading and position.
Drifthook
When active, the boat attempts to maintain heading, but the position may change.
Bowhook
When active, the boat attempts to keep the same position, but the heading may change.
Adding the Skyhook Digital Anchor Control Overlay
When connected to a compatible Mercury engine, you can add an overlay on the chartplotter to control the Skyhook digital anchor functions.
  1. From the page where you want to add the overlay, select Menu options symbol > Edit Overlays.
    TIP: You can also select Toolbar icon from the menu bar to quickly change the overlays.
  2. Select Top Bar, Bottom Bar, Left Bar, or Right Bar.
  3. Select Mercury Skyhook.
  4. Select Back.
Skyhook Digital Anchor Overlay
When connected to a compatible Mercury engine, you can use the Skyhook overlay on the chartplotter to control the Skyhook digital anchor functions.
TIP: When the Skyhook digital anchor, Drifthook feature, or Bowhook feature is active, you can select Standby on the menu bar to disengage the active digital anchor feature and resume manual control of the boat.
Mercury Skyhook bar with callouts
1
Information about the current heading and steering adjustments.
Skip back icon
Adjusts the intended heading to port. The system steers the boat to the new heading.
Skip forward icon
Adjusts the intended heading to starboard. The system steers the boat to the new heading.
Drifthook
Changes to Drifthook functionality.
Bowhook
Changes to Bowhook functionality.
Drifthook Overlay
When the Skyhook overlay is enabled on the chartplotter, you can select Drifthook to change the Skyhook digital anchor to use the Drifthook function.
TIP: When the Drifthook feature is active, you can select Standby on the menu bar to disengage the anchor and resume manual control of the boat.
Mercury Drifthook bar
Skip back icon
Skip forward icon
Drifthook
Select again to return to Skyhook digital anchor functionality.
Bowhook
GUID-9A17B80C-F7A5-4535-8E7D-E8F0ECD1DCD4 v9
September 2025
