Enabling Group Synchronization
You must remove the stereo from an existing group before you can enable the Save Group setting. You cannot update settings when a stereo is part of a group.
You must enable this setting on each stereo that you want to retain group settings after a power cycle.
  1. From the Media screen, select Menu options symbol > Installation.
  2. Select the name of the stereo.
  3. Select Power Options > Save Group.
    The stereo retains group settings after a power cycle.
  4. Repeat for additional stereos as needed.
NOTE: You must enable Save Group on all networked stereos for synchronization to work properly.
September 2026
