Copying User Data from a Specified Area to a Memory Card
You can save user data from a specified area to a memory card to transfer to other devices. User data includes waypoints, routes, Auto Guidance paths, tracks, and boundaries.
  1. Insert a memory card into the card slot.
  2. Select Where To.
  3. From the menu bar, select Menu button.
  4. Select Manage User Data > Data Transfer > Save Area to Card.
  5. Select an option:
    • If you previously defined an area boundary containing user data you want to transfer, select the name of the area and select Select Area.
    • If you want to define a new area containing user data to transfer, select New Area, and follow the on-screen instructions to define the area.
  6. Select Save Area to Card.
  7. If necessary, select the memory card to copy the data to.
  8. Select an option:
    • To create a new file, select Add New File, and enter a name.
    • To add the information to an existing file, select the file from the list, and select Save to Card.
September 2026
