Setting Up and Following the Zigzag Pattern
You can use the zigzag pattern to steer the boat from port to starboard and back, over a specified time and angle, across your present heading.
  1. From the autopilot screen, select Menu options symbol > Pattern Steering > Zigzag.
  2. If necessary, select Amplitude, and select a degree.
  3. If necessary, select Period, and select a length of time.
  4. Select Engage Zigzag.
June 2026
