Creating and Navigating a Route From Your Present Location
You can create and immediately navigate a route on the Navigation chart or the Fishing chart. This method does not save the route.
  1. From the Navigation chart or Fishing chart, select a destination.
  2. Select Route To.
  3. Select the location of the last turn before the destination.
  4. Select Add Turn.
  5. If necessary, repeat to add turns, working backward from the destination to the present location of your vessel.
    The last turn you add should be the first turn you make, starting from your present location. It should be the turn closest to your vessel.
  6. Select Done.
  7. Review the course indicated by the magenta line.
  8. Follow the magenta line, steering to avoid land, shallow water, and other obstacles.
    NOTE: In the center of the magenta line is a thinner purple line that represents the direct course from your current location to the next route turn. The direct course is dynamic, and it moves with your boat when you are off course.
June 2026
