Transducer Installation Settings
These settings apply to the following types of sonar.
  • Traditional
  • Garmin ClearVü™
  • Garmin SideVü™
From an applicable sonar view, select an option.
  • From a Traditional sonar view, select Menu options symbol > Sonar Setup > Installation.
  • From a Garmin ClearVü sonar view, select Menu options symbol > ClearVü Setup > Installation.
  • From a Garmin SideVü sonar view, select Menu options symbol > SideVü Setup > Installation.
Flip Left/Right
Switches the SideVü view orientation from left to right. This option is available on the SideVü sonar view only.
Restore Sonar Defaults
Restores the sonar settings to the factory default values.
Transducers
View details about installed transducers and save details to a memory card.
Transducers > Change Model
Allows you to change an installed transducer type (Selecting the Transducer Type).
Transducers > Manual Configuration
Allows you to set manual transducer configuration parameters on a compatible sonar module. See the installation instructions for your compatible sonar module for more details on connecting and manually configuring a transducer.
September 2026
