Tips After Pairing the Devices
After the initial pairing, the two devices can connect automatically each time you turn them on.
When your phone is connected to your device, you are ready to receive voice calls.
When you turn on the device, it tries to connect to the last phone to which it was connected.
You might need to set your phone to connect to the device automatically when the device is turned on.
To place phone calls, the contact sharing permission must be enabled for the navigation device in the Bluetooth® settings on your phone.
You should verify the Bluetooth features you want to use are enabled.
Parent Topic: Pairing Your Phone
