Formatting the Memory Card
The device requires a memory card formatted using the FAT32 file system. You can use the device to format your card using this file system.
You must format a brand new memory card if it is not formatted using the FAT32 file system.
NOTE:
Formatting the memory card deletes all data on the card.
- Select .
- Select your memory card.
- Select .
- Select Done.
Parent Topic: Data Management
