Playing Audio Prompts During Your Activity
You can enable your watch to play motivational status announcements during a run or other activity. Audio prompts play on your connected headphones using Bluetooth® technology, if available. Otherwise, audio prompts play on your phone paired through the Garmin Connect™ app. During an audio prompt, the watch or phone mutes the primary audio to play the announcement.
- From the watch face, hold UP.
- Select .
Select an option:
To hear a prompt for each lap, select Lap Alert.
NOTE: The Lap Alert audio prompt is enabled by default. -
To customize prompts with your pace and speed data, select Pace/Speed Alert.
To customize prompts with your heart rate data, select Heart Rate Alert.
To hear prompts when you start and stop the timer, including the Auto Pause® feature, select Timer Events.
To hear prompts for each workout step, select Workout Alerts.
To hear activity alerts play as an audio prompt, select Activity Alerts.
To hear a sound play right before an audio alert or prompt, select Audio Tones.
To change the language or the dialect of the voice prompts, select Dialect.
