Calibrating Your Foot Pod Manually
Before you can calibrate your device, you must pair your device with the foot pod sensor (Pairing Your Wireless Sensors).
Manual calibration is recommended if you know your calibration factor. If you have calibrated a foot pod with another Garmin® product, you may know your calibration factor.
  1. From the watch face, hold UP.
  2. Select Menu symbol > Sensors & Accessories.
  3. Select your foot pod.
  4. Select Cal. Factor > Set Value.
  5. Adjust the calibration factor:
    • Increase the calibration factor if your distance is too low.
    • Decrease the calibration factor if your distance is too high.
Copyright © Garmin. All rights reserved.GUID-E6C8A24B-F810-4256-9F04-557F6B4B102F v8
