Viewing the Body Battery Widget
The Body Battery™ widget displays your current Body Battery level and a graph of your Body Battery level for the last several hours.
  1. Select UP or DOWN to view the Body Battery widget.
    NOTE: You may need to add the widget to your widget loop (Customizing the Widget Loop).
    Body Battery data
  2. Select START to view a combined graph of your Body Battery and stress level.
    Blue bars indicate periods of rest. Orange bars indicate periods of stress. Gray bars indicate times that you were too active to determine your stress level.
    Stress level data
  3. Select DOWN to see your Body Battery data since midnight.
    Body Battery data
Copyright © Garmin. All rights reserved.GUID-E6C8A24B-F810-4256-9F04-557F6B4B102F v8
