Going for a Track Run
Before you go for a track run, make sure you are running on a standard-shape, 400 m track.
You can use the track run activity to record your outdoor track data, including distance in meters and lap splits.
  1. Stand on the outdoor track.
  2. Select START > Track Run.
  3. Wait while the device locates satellites.
  4. If you are running in lane 1, skip to step 10.
  5. Hold UP.
  6. Select the activity settings.
  7. Select Lane Number.
  8. Select a lane number.
  9. Select BACK twice to return to the activity timer.
  10. Select START.
  11. Run around the track.
    After you run 3 laps, your device records the track dimensions and calibrates your track distance.
  12. After you complete your run, select STOP > Save.
Copyright © Garmin. All rights reserved.GUID-E6C8A24B-F810-4256-9F04-557F6B4B102F v8
