Tips for Recording a Track Run
  • Wait until the GPS status indicator turns green before starting a track run.
  • During your first run on an unfamiliar track, run for a minimum of 3 laps to calibrate your track distance.
    You should run slightly past your starting point to complete the lap.
  • Run each lap in the same lane.
    NOTE: The default Auto Lap® distance is 1600 m, or 4 laps around the track.
  • If you are running in a lane other than lane 1, set the lane number in the activity settings.
Copyright © Garmin. All rights reserved.GUID-E6C8A24B-F810-4256-9F04-557F6B4B102F v8
