How can I manually pair ANT+ sensors?
You can use the device settings to manually pair ANT+® sensors. The first time you connect a sensor to your device using ANT+ wireless technology, you must pair the device and sensor. After they are paired, the device connects to the sensor automatically when you start an activity and the sensor is active and within range.
Parent Topic: Troubleshooting
