Vertical Oscillation and Vertical Ratio Data
The data ranges for vertical oscillation and vertical ratio are slightly different depending on the sensor and whether it is positioned at the chest (HRM‍-‍Tri™ or HRM‍-‍Run™ accessories) or at the waist (Running Dynamics Pod accessory).
Color Zone
Percentile in Zone
Vertical Oscillation Range at Chest
Vertical Oscillation Range at Waist
Vertical Ratio at Chest
Vertical Ratio at Waist
Purple Purple
>95
<6.4 cm
<6.8 cm
<6.1%
<6.5%
Blue Blue
70–95
6.4–8.1 cm
6.8–8.9 cm
6.1–7.4%
6.5–8.3%
Green Green
30–69
8.2–9.7 cm
9.0–10.9 cm
7.5–8.6%
8.4–10.0%
Orange Orange
5–29
9.8–11.5 cm
11.0–13.0 cm
8.7–10.1%
10.1–11.9%
Red Red
<5
>11.5 cm
>13.0 cm
>10.1%
>11.9%
Copyright © Garmin. All rights reserved.GUID-E6C8A24B-F810-4256-9F04-557F6B4B102F v8
