Connecting to a Wi‑Fi Network
You must connect your device to the Garmin Connect™ app on your smartphone or to the Garmin Express™ application on your computer before you can connect to a Wi‑Fi® network.
To sync your device with a third-party music provider, you must connect to Wi‑Fi. Connecting the device to a Wi‑Fi network also helps to increase the transfer speed of larger files.
  1. Move within range of a Wi‑Fi network.
  2. From the Garmin Connect app, select Menu symbol or Menu symbol.
  3. Select Garmin Devices, and select your device.
  4. Select General > Wi-Fi Networks > Add a Network.
  5. Select an available Wi‑Fi network, and enter the login details.
Copyright © Garmin. All rights reserved.GUID-E6C8A24B-F810-4256-9F04-557F6B4B102F v8
