Can I use my Bluetooth sensor with my watch?
The device is compatible with some Bluetooth® sensors. The first time you connect a sensor to your Garmin® device, you must pair the device and sensor. After they are paired, the device connects to the sensor automatically when you start an activity and the sensor is active and within range.
  1. Hold UP.
  2. Select Menu symbol > Sensors & Accessories > Add New.
  3. Select an option:
    • Select Search All.
    • Select your sensor type.
    You can customize the optional data fields (Customizing the Data Screens).
Copyright © Garmin. All rights reserved.GUID-E6C8A24B-F810-4256-9F04-557F6B4B102F v8
