You can broadcast your heart rate data from your
Forerunner® device and view it on paired
Garmin® devices.
NOTE:
Broadcasting heart rate data decreases battery life.
From the heart rate widget, hold
UP.
Select
The
Forerunner device starts broadcasting your heart rate data, and
appears.
NOTE:
You can view only the heart rate widget while broadcasting heart rate data from the heart rate widget.
Pair your
Forerunner device with your
Garmin
ANT+® compatible device.
NOTE:
The pairing instructions differ for each
Garmin compatible device. See your owner's manual.
TIP:
To stop broadcasting your heart rate data, select any key, and select
Yes.
