Data Fields
Some data fields require ANT‍+® accessories to display data.
% Heart Rate Reserve
The percentage of heart rate reserve (maximum heart rate minus resting heart rate).
24-Hour Maximum
The maximum temperature recorded in the last 24 hours from a compatible temperature sensor.
24-Hour Minimum
The minimum temperature recorded in the last 24 hours from a compatible temperature sensor.
Aerobic Training Effect
The impact of the current activity on your aerobic fitness level.
Anaerobic Training Effect
The impact of the current activity on your anaerobic fitness level.
Average % Heart Rate Reserve
The average percentage of heart rate reserve (maximum heart rate minus resting heart rate) for the current activity.
Average Cadence
Running. The average cadence for the current activity.
Average Cadence
Cycling. The average cadence for the current activity.
Average GCT Balance
The average ground contact time balance for the current session.
Average Ground Contact Time
The average amount of ground contact time for the current activity.
Average Heart Rate
The average heart rate for the current activity.
Average Heart Rate %Max.
The average percentage of maximum heart rate for the current activity.
Average Lap Time
The average lap time for the current activity.
Average Pace
The average pace for the current activity.
Average Speed
The average speed for the current activity.
Average Stride Length
The average stride length for the current session.
Average Stroke Rate
Paddle sports. The average number of strokes per minute (spm) during the current activity.
Average Strokes Per Length
The average number of strokes per pool length during the current activity.
Average Swolf
The average swolf score for the current activity. Your swolf score is the sum of the time for one length plus the number of strokes for that length (Swim Terminology).
Average Vertical Oscillation
The average amount of vertical oscillation for the current activity.
Average Vertical Ratio
The average ratio of vertical oscillation to stride length for the current session.
Battery Level
The remaining battery power.
Bearing
The direction from your current location to a destination. You must be navigating for this data to appear.
Cadence
Running. The steps per minute (right and left).
Cadence
Cycling. The number of revolutions of the crank arm. Your device must be connected to a cadence accessory for this data to appear.
Calories
The amount of total calories burned.
Course
The direction from your starting location to a destination. Course can be viewed as a planned or set route. You must be navigating for this data to appear.
Destination Location
The position of your final destination.
Destination Waypoint
The last point on the route to the destination. You must be navigating for this data to appear.
Distance
The distance traveled for the current track or activity.
Distance Remaining
The remaining distance to the final destination. You must be navigating for this data to appear.
Distance To Next
The remaining distance to the next waypoint on the route. You must be navigating for this data to appear.
Elapsed Time
The total time recorded. For example, if you start the timer and run for 10 minutes, then stop the timer for 5 minutes, then start the timer and run for 20 minutes, your elapsed time is 35 minutes.
Elevation
The altitude of your current location above or below sea level.
Estimated Total Distance
The estimated distance from the start to the final destination. You must be navigating for this data to appear.
ETA
The estimated time of day when you will reach the final destination (adjusted to the local time of the destination). You must be navigating for this data to appear.
ETA at Next
The estimated time of day when you will reach the next waypoint on the route (adjusted to the local time of the waypoint). You must be navigating for this data to appear.
ETE
The estimated time remaining until you reach the final destination. You must be navigating for this data to appear.
GCT Balance
The left/right balance of ground contact time while running.
GPS
The strength of the GPS satellite signal.
Ground Contact Time
The amount of time in each step that you spend on the ground while running, measured in milliseconds. Ground contact time is not calculated while walking.
Heading
The direction you are moving.
Heart Rate
Your heart rate in beats per minute (bpm). Your device must be connected to a compatible heart rate monitor.
Heart Rate %Max.
The percentage of maximum heart rate.
Heart Rate Zone
The current range of your heart rate (1 to 5). The default zones are based on your user profile and maximum heart rate (220 minus your age).
Interval Average %HRR
The average percentage of heart rate reserve (maximum heart rate minus resting heart rate) for the current swim interval.
Interval Average %Max.
The average percentage of maximum heart rate for the current swim interval.
Interval Average Heart Rate
The average heart rate for the current swim interval.
Interval Distance
The distance traveled for the current interval.
Interval Lengths
The number of pool lengths completed during the current interval.
Interval Maximum %HRR
The maximum percentage of heart rate reserve (maximum heart rate minus resting heart rate) for the current swim interval.
Interval Maximum %Max.
The maximum percentage of maximum heart rate for the current swim interval.
Interval Maximum Heart Rate
The maximum heart rate for the current swim interval.
Interval Pace
The average pace for the current interval.
Interval Stroke Rate
The average number of strokes per minute (spm) during the current interval.
Interval Strokes Per Length
The average number of strokes per pool length during the current interval.
Interval Stroke Type
The current stroke type for the interval.
Interval Swolf
The average swolf score for the current interval.
Interval Time
The stopwatch time for the current interval.
Lap % Heart Rate Reserve
The average percentage of heart rate reserve (maximum heart rate minus resting heart rate) for the current lap.
Lap Cadence
Running. The average cadence for the current lap.
Lap Cadence
Cycling. The average cadence for the current lap.
Lap Distance
The distance traveled for the current lap.
Lap GCT Balance
The average ground contact time balance for the current lap.
Lap Ground Contact Time
The average amount of ground contact time for the current lap.
Lap Heart Rate
The average heart rate for the current lap.
Lap Heart Rate %Max.
The average percentage of maximum heart rate for the current lap.
Lap Pace
The average pace for the current lap.
Laps
The number of laps completed for the current activity.
Lap Speed
The average speed for the current lap.
Lap Stride Length
The average stride length for the current lap.
Lap Stroke Rate
Paddle sports. The average number of strokes per minute (spm) during the current lap.
Lap Strokes
Paddle sports. The total number of strokes for the current lap.
Lap Time
The stopwatch time for the current lap.
Lap Vertical Oscillation
The average amount of vertical oscillation for the current lap.
Lap Vertical Ratio
The average ratio of vertical oscillation to stride length for the current lap.
Last Lap %HRR
The average percentage of heart rate reserve (maximum heart rate minus resting heart rate) for the last completed lap.
Last Lap Cadence
Running. The average cadence for the last completed lap.
Last Lap Cadence
Cycling. The average cadence for the last completed lap.
Last Lap Distance
The distance traveled for the last completed lap.
Last Lap Heart Rate
The average heart rate for the last completed lap.
Last Lap Heart Rate %Max.
The average percentage of maximum heart rate for the last completed lap.
Last Lap Pace
The average pace for the last completed lap.
Last Lap Speed
The average speed for the last completed lap.
Last Lap Stroke Rate
Paddle sports. The average number of strokes per minute (spm) during the last completed lap.
Last Lap Strokes
Paddle sports. The total number of strokes for the last completed lap.
Last Lap Time
The stopwatch time for the last completed lap.
Last Length Pace
The average pace for your last completed pool length.
Last Length Stroke Rate
The average number strokes per minute (spm) during the last completed pool length.
Last Length Strokes
The total number of strokes for the last completed pool length.
Last Length Stroke Type
The stroke type used during the last completed pool length.
Last Length Swolf
The swolf score for the last completed pool length.
Lat/Lon
The current position in latitude and longitude regardless of the selected position format setting.
Lengths
The number of pool lengths completed during the current activity.
Location
The current position using the selected position format setting.
Maximum Speed
The top speed for the current activity.
Next Split Distance
Running. The total distance of the next split.
Next Split Target Pace
Running. The target pace for the next split.
Next Waypoint
The next point on the route. You must be navigating for this data to appear.
Off Course
The distance to the left or right by which you have strayed from the original path of travel. You must be navigating for this data to appear.
Overall Ahead/Behind
Running. The overall time ahead of or behind the target pace.
Pace
The current pace.
Performance Condition
The performance condition score is a real-time assessment of your ability to perform.
Repeat On
The timer for the last interval plus the current rest (pool swimming).
Reps
During a strength training activity, the number of repetitions in a workout set.
Respiration Rate
Your respiration rate in breaths per minute (brpm).
Rest Timer
The timer for the current rest (pool swimming).
Set Timer
During a strength training activity, the amount of time spent in the current workout set.
Speed
The current rate of travel.
Split Distance
Running. The total distance of the current split.
Split Distance Remaining
Running. The remaining distance of the current split.
Split Pace
Running. The pace for the current split.
Split Target Pace
Running. The target pace for the current split.
Stress
Your current stress level.
Stride Length
The length of your stride from one footfall to the next, measured in meters.
Stroke Rate
Swimming. The number of strokes per minute (spm).
Stroke Rate
Paddle sports. The number of strokes per minute (spm).
Strokes
Paddle sports. The total number of strokes for the current activity.
Sunrise
The time of sunrise based on your GPS position.
Sunset
The time of sunset based on your GPS position.
Swim Time
The swimming time for the current activity, not including rest time.
Temperature
The temperature of the air. Your body temperature affects the temperature sensor.
Time in Zone
The time elapsed in each heart rate zone.
Time of Day
The time of day based on your current location and time settings (format, time zone, daylight saving time).
Timer
The stopwatch time for the current activity.
Time to Next
The estimated time remaining before you reach the next waypoint in the route. You must be navigating for this data to appear.
Velocity Made Good
The speed at which you are closing on a destination along a route. You must be navigating for this data to appear.
The amount of bounce while you are running. The vertical motion of your torso, measured in centimeters for each step.
Vertical Ratio
The ratio of vertical oscillation to stride length.
Copyright © Garmin. All rights reserved.GUID-E6C8A24B-F810-4256-9F04-557F6B4B102F v8
