Cleaning the Watch
CAUTION
Some users may experience skin irritation after prolonged use of the watch, especially if the user has sensitive skin or allergies. If you notice any skin irritation, remove the watch and give your skin time to heal. To help prevent skin irritation, ensure the watch is clean and dry, and do not overtighten the watch on your wrist.
NOTICE
Even small amounts of sweat or moisture can cause corrosion of the electrical contacts when connected to a charger. Corrosion can prevent charging and data transfer.
  1. Wipe the watch using a cloth dampened with a mild detergent solution.
  2. Wipe it dry.
After cleaning, allow the watch to dry completely.
TIP: For more information, go to www.garmin.com/fitandcare.
Copyright © Garmin. All rights reserved.GUID-E6C8A24B-F810-4256-9F04-557F6B4B102F v8
