Setting Resistance Select Training > Indoor Trainer > Set Resistance. Set the resistance force applied by the trainer. Select an activity profile. Start pedaling. If necessary, you can adjust the resistance during your activity. Parent Topic: Using an ANT+ Indoor Trainer
Setting Resistance Select Training > Indoor Trainer > Set Resistance. Set the resistance force applied by the trainer. Select an activity profile. Start pedaling. If necessary, you can adjust the resistance during your activity. Parent Topic: Using an ANT+ Indoor TrainerHomeTrainingTraining IndoorsUsing an ANT+ Indoor TrainerSetting Resistance
