Updating Your Activity Profile
You can customize ten activity profiles. You can customize your settings and data fields for a particular activity or trip.
Select
> Settings > Activity Profiles.
Select an option:
Select a profile.
Select
> Add.
- If necessary, edit the name and color for the profile.
Select an option:
Select Data Screens to customize the data screens and data fields (Customizing the Data Screens).
Select Default Ride Type to set the type of ride that is typical for this activity profile, such as commuting.TIP: After a ride that is not typical, you can manually update the ride type. Accurate ride type data is important for creating bike friendly courses.
Select GPS Mode to turn off GPS (Training Indoors) or change the satellite setting (Changing the Satellite Setting).
Select Navigation to customize the map settings (Map Settings) and routing settings (Route Settings).
Select Alerts to customize your training alerts (Alerts).
Select Auto Features > Auto Lap to set how laps are triggered (Marking Laps by Position).
Select Auto Features > Auto Pause to change when the timer automatically pauses (Using Auto Pause).
Select Auto Features > Auto Sleep to automatically enter sleep mode after five minutes of inactivity (Using Auto Sleep).
Select Auto Features > Auto Scroll to customize the display of the training data screens when the timer is running (Using Auto Scroll).
Select Timer Start Mode to customize how the device detects the start of a ride and automatically starts the timer (Starting the Timer Automatically).
All changes are saved to the activity profile.
