Using an ANT‍+ Indoor Trainer
Before you can use a compatible ANT‍+® indoor trainer, you must mount your bike on the trainer and pair it with your device (Pairing Your ANT‍+ Indoor Trainer).
You can use your device with an indoor trainer to simulate resistance while following a course, activity, or workout. While using an indoor trainer, GPS is turned off automatically.
  1. Select Training > Indoor Trainer.
  2. Select an option:
    • Select Follow a Course to follow a saved course (Courses).
    • Select Follow an Activity to follow a saved ride (Going for a Ride).
    • Select Follow a Workout to follow a power-based workout downloaded from your Garmin Connect™ account (Workouts).
  3. Select a course, activity, or workout.
  4. Select Ride.
  5. Select an activity profile.
  6. Select Pause play symbol to start the timer.
    The trainer increases or decreases resistance based on the elevation information in the course or ride.
Copyright © Garmin. All rights reserved.GUID-13DDC698-D64B-4D27-B790-38A7EAE15395 v3
