Turning On Battery Save Mode
Battery save mode adjusts the settings automatically to extend the battery life for longer rides. During an activity, the screen turns off. You can enable automatic alerts and tap the screen to wake it up. Battery save mode records GPS track points and sensor data less frequently. Speed, distance, and track data accuracy are reduced.
NOTE: History is recorded in battery save mode when the timer is running.
  1. Select Menu symbol > Settings > Battery Save Mode > Enable.
  2. Select the alerts that wake up the screen during an activity.
Copyright © Garmin. All rights reserved.GUID-13DDC698-D64B-4D27-B790-38A7EAE15395 v3
